https://linustechtips.com/topic/68227-water-block-compatibility/
www.coolingconfigurator.com
If the standard EK block fits, all the standard blocks will fit. It means your PCB is reference.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/68227-water-block-compatibility/#findComment-934380
