Hi,
I picked my parts for my first pc, but I'm not entirely sure about the MOBO. Does it have all the necessary plugs? Are there other problems with the MOBO or build or should I pick another part? I'm so confused...
http://de.pcpartpicker.com/list/HmVL7h
Thank you, I appreciate your time.
https://linustechtips.com/topic/682017-i-need-help-please/
As far as I can tell you're good to go. I don't see any issues with that motherboard and the case or the ports. :)
Yes, it's 2871 as in the year 2871. I traveled all this way, back in time, just to help you. And you thought your mama lied when she said you were special-_-
https://linustechtips.com/topic/682017-i-need-help-please/#findComment-8768615
