hello. i just got my gigabyte z170x-ultra gaming mobo and a core i7 6700k (along with other stuff for my upgrade). i put everything on outside the case and, to my dismay, i discovered that nothing happened when i turned on the power supply. i tested the PSU with the supplied test...thingy and it works. i've tried it with and without the ram and graphics card and notta. i did use the pre-applied thermal paste that was on the corsair H100i, but cleaned it off with rubbing alcohol and went with arctic silver 5. when i took out the CPU just to see if everything was on the up and up, i discovered that a pin somehow got bent. i used a tiny needle to try and move it back and it looked to be back to normal but its still not doing anything. did i just royally screw myself by attempting to fix the pin or could this just be a dead mobo?
https://linustechtips.com/topic/681872-motherboard-or-cpu-issue/
4 minutes ago, dethsight said:
i was afraid of that. i havent told them anything yet but i do have an RMA on it already. what a way to start my FIRST build. :/
Did you press down on the cpu when you put it in the socket? Because youre not supposed to, and that would be the number 1 cause of pin bending
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
https://linustechtips.com/topic/681872-motherboard-or-cpu-issue/#findComment-8767092
i didn't. i did the "line it up then lower it down" method with the CPU wiggle method at the end.
https://linustechtips.com/topic/681872-motherboard-or-cpu-issue/#findComment-8767100
CPU wiggle? I never wiggled my cpu. Id say avoid that in the future.
https://linustechtips.com/topic/681872-motherboard-or-cpu-issue/#findComment-8767107
"wiggling" the CPU is safe. A little bit of pressure to wiggle it into place won't bend pins. The pin was probably already bent.
i5-6600k (4.6) | Dark Rock 3 | MSI GAMING X 1060 6GB | 8GB DDR4 | 120GB SSD & 1TB HDD | Crystal 460x
 | Acer GN246HL 1080p 24" 144hz & Acer G246HL 1080p 24" 60hz |
PSU Tier List | PC Partpickers: US Canada Australia UK
https://linustechtips.com/topic/681872-motherboard-or-cpu-issue/#findComment-8767130
yea i went ahead and removed the cpu and checked the pins again. nothing was noticeably bent but i know they are incredibly sensitive. its all packaged back up now and will be back to newegg tomorrow. (the mobo at least)
https://linustechtips.com/topic/681872-motherboard-or-cpu-issue/#findComment-8767155
