Hi I just bought upgrades for my pc and I ran into a problem. I went to go turn on my PC and its not posting. I have the Z170-A motherboard and it has LED lights to tell me what specific parts are working and not working. The boot device LED is solid red. I thought it was a motherboard problem so I got a new Z170-A motherboard shipped to me and I got the same results. Ive checked all the cables again and again and I dont see a problem anywhere
http://pcpartpicker.com/user/ThatOneMaou/saved/rfXHxr
This is my build I reused my 1tb western blue hard drive and graphics card.
https://linustechtips.com/topic/681695-need-help-asap-please/
Try to change the ram slot and make sure that it is in the correct slot by checking your motherboard manual if it isnt working , try the second PCI slot on your motherboard and put he Graphics card in it . If it doen't help try removing thegigabyte card and run on integrated graphics . If that doesn't help too , i hope trying another power supply to power up the system . The worse case is a problem with the cpu . Waiting for your answer :)
https://linustechtips.com/topic/681695-need-help-asap-please/#findComment-8764980
