Afternoon LTT,
I have 2 GTX 970's running in SLI in my PC.
As I turned on my PC, my temperature of one of my graphics cards was in the high 50's whilst idle (normally 30degrees) so I removed the graphics card, rebooted and all seemed well.
Upon plugging back in the GPU the same problem occurred, so I took it out again, had a look if there was any dust build up (there wasn't) and plugged it back in on its own.
I have a display but the temperature is still in the high 50's
I decided to run fire strike, which didn't even boot up after loading and I got an error.
I've tried both PCI-E slots. Cleaning the GPU. Reseating the cables.
Both GPU's are NOT overclocked and run at factory settings.
Anyone think of any issues?
https://linustechtips.com/topic/681253-gtx-970-issues/
5 minutes ago, FactumPCs said:
Afternoon LTT,
Should try em in another pc / Try another gpu in ur pc..
But I had a 970 and it was running in these temp... 50 idle.. 73 on load..
Also maybe posting the error you got in firestrike could help
https://linustechtips.com/topic/681253-gtx-970-issues/#findComment-8760104
Okay, tried in another PC, same issues. Tried another GPU in mine, works fine.
FireStrike says workload produced no results.
Might give ASUS tech support a ring in the morning.
https://linustechtips.com/topic/681253-gtx-970-issues/#findComment-8760177
Good troubleshooting, now you know its the gpu the issue. Not your board :)
Good luck with the asus support
https://linustechtips.com/topic/681253-gtx-970-issues/#findComment-8760343
