 Recently my pc took a dump.
I have a gtx 750ti
16 gb ddr3 ram
Case (duh lol)
And a 300w power supply.
In regards as to what I need.
A new motherboard and prossessor.
I'm going to just install steam os for now because windows is so damn expencive.
I'm looking to spend
no more than 100 USD but I cannot find anything that's any good.
I play arma so a high clock speed would be nice but I can sacrifice playing high end games for now.
If anyone has suggestions as to what I could get please reply with anything you find.
With much thanks.
Drifter
https://linustechtips.com/topic/681043-please-help/
I have a gtx 750ti
16 gb ddr3 ram
Case (duh lol)
With much thanks.
Drifter
http://pcpartpicker.com/product/sZh9TW/asrock-motherboard-970pro3r20
http://pcpartpicker.com/product/cpvRsY/amd-cpu-ad250usck23gq
This is not going to be fast, but it does fit your budget.
Yes, it's 2871 as in the year 2871. I traveled all this way, back in time, just to help you. And you thought your mama lied when she said you were special-_-
https://linustechtips.com/topic/681043-please-help/#findComment-8757667
I find it hard to believe that both your CPU and motherboard died. maybe it was misdiagnosed.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/681043-please-help/#findComment-8757686
I have a gtx 750ti
16 gb ddr3 ram
Case (duh lol)
With much thanks.
Drifter
are you okay with used stuff?
https://linustechtips.com/topic/681043-please-help/#findComment-8757687
Agreed. Used is the best option. maybe a Haswell or Ivy bridge i3
Laptop:
https://linustechtips.com/topic/681043-please-help/#findComment-8757710
