Hello guys!
This is my first build, here are the parts I've chosen - http://in.pcpartpicker.com/list/TM9Khq
Is this a decent one? Any bottlenecks? Changes? etc....?
Also, I don't have a keyboard, so what's the cheapest decent keyboard I can buy (Around ₹2000)?
And Is that a good monitor?
Thanks!
Edit: Any major performance impacts if I swap my 6500 with a 6400?
https://linustechtips.com/topic/680750-budget-gaming-build-help/
3 minutes ago, Alexzz_ said:
seems like a good build, however i would advise you to upgrade your storage soon after you get this build, 120 Gb runs out fast if you store a lot of things.
https://linustechtips.com/topic/680750-budget-gaming-build-help/#findComment-8754405
get the 6500. Its better in cpu bound games and one day you will regret it for one reason or another that you got a 6400.
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/680750-budget-gaming-build-help/#findComment-8754414
2 minutes ago, Vishvas Sudarshan said:
Yup agree, but how do I squeeze a keyboard in there? Any suggestions?
http://in.pcpartpicker.com/list/PNrGjc
would this work?
https://linustechtips.com/topic/680750-budget-gaming-build-help/#findComment-8754430
1 minute ago, Mohenjo said:
I have a question, will getting a 'more expensive' membrane keyboard be better? Like the AZIO L50?
(Not that I'm gonna buy it, genuine question)
https://linustechtips.com/topic/680750-budget-gaming-build-help/#findComment-8754445
eh, a keyboard is a keyboard. Membrane is nothing special
https://linustechtips.com/topic/680750-budget-gaming-build-help/#findComment-8754459
