Hello,
I am working on designing a parts list for my friend and am having some trouble. He needs it to be $450, have an i5 or amd equivelant, and both a pcie x1 and pcie x16 MOBO slot. And preferably a mini tower or similar size.
This build will be for gaming and capturing with an elgato game capture pro card.
Ive been working on this for about a week so please dont suggest pc partpicker searching.
IM BACK BABY
https://linustechtips.com/topic/680393-450-build-list-help/
1 minute ago, kurtstir said:
Hello,
I am working on designing a parts list for my friend and am having some trouble. He needs it to be $450, have an i5 or amd equivelant, and both a pcie x1 and pcie x16 MOBO slot. And preferably microatx or similar size
For what purpose? Gaming?
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/680393-450-build-list-help/#findComment-8750613
7 minutes ago, kurtstir said:
Hello,
http://pcpartpicker.com/list/FbdnGf just tell uir friend to save for this, it is best bet.
MF UH BEANS
https://linustechtips.com/topic/680393-450-build-list-help/#findComment-8750629
3 minutes ago, kurtstir said:
Gaming and capturing
I would definitely advise waiting until your friend can spend $700 on the computer, but if it can't be helped.
CPU: AMD FX-8300 3.3GHz 8-Core Processor  ($114.99 @ Newegg)
CPU Cooler: Deepcool GAMMAXX 400 74.3 CFM CPU Cooler  ($14.99 @ Newegg)
Motherboard: ASRock 970A-G/3.1 ATX AM3+/AM3 Motherboard  ($56.98 @ Newegg)
Memory: *Mushkin Essentials 8GB (2 x 4GB) DDR3-1333 Memory  ($34.83 @ OutletPC)
Storage: *Hitachi Deskstar 1TB 3.5" 7200RPM Internal Hard Drive  ($37.50 @ Amazon)
Video Card: *PowerColor Radeon RX 460 2GB Red Dragon Video Card  ($99.98 @ Newegg)
Case: *Thermaltake Versa H25 ATX Mid Tower Case  ($37.99 @ SuperBiiz)
Power Supply: *Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($25.00 @ Newegg)
Total: $422.26
Generated by PCPartPicker 2016-10-24 18:44 EDT-0400
Computer Specs:
https://linustechtips.com/topic/680393-450-build-list-help/#findComment-8750653
CPU: AMD FX-8350 4.0GHz 8-Core Processor  ($151.98 @ Newegg)
Video Card: XFX Radeon RX 460 4GB Double Dissipation Video Card  ($114.99 @ Newegg)
Total: $451.27
Generated by PCPartPicker 2016-10-24 20:02 EDT-0400
no cooler needed because the wraith cooler on the 8350 is actually very good for overclocking
Edited by gtx1060=value
https://linustechtips.com/topic/680393-450-build-list-help/#findComment-8750967
Motherboard: Asus M5A78L-M/USB3 Micro ATX AM3+ Motherboard  ($36.98 @ Newegg)
Memory: Patriot Viper 3 8GB (1 x 8GB) DDR3-1600 Memory  ($35.00 @ B&H)
Video Card: XFX Radeon RX 470 4GB Triple X Video Card  ($174.98 @ Newegg)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($24.99 @ SuperBiiz)
Total: $449.44
Generated by PCPartPicker 2016-10-24 20:15 EDT-0400
https://linustechtips.com/topic/680393-450-build-list-help/#findComment-8751031
http://pcpartpicker.com/list/wKz64C
It seems everyone is recommending fx 8000 series cpus because your freind wants to record gameplay. From first hand experiance a stock fx8320 can only handle a soft 720p output without sh*tting itself. Thankfully both nvidia and AMD have solutions to utilise the gpu for this(shadowplay for nvidia and plays.tv for amd)
The build came in at $500 not including the OS, but there are plenty of ways to get that cheap/free. If your freind can scrap together another $50 this will be a very good entry build. However as I seem to be telling everyone; used gtx 780s go for $100-$125 dollars on ebay, so if you are willing to go used you can bring down the cost right to budget.
https://linustechtips.com/topic/680393-450-build-list-help/#findComment-8751205
its decent, by no means bad
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/680393-450-build-list-help/#findComment-8753352
4 minutes ago, kurtstir said:
Does this look like a good build? The budget is $450.
http://pcpartpicker.com/user/kurtstir/saved/2tyXLk
I personally would save up a bit more. like $700 or $800 also its coming to the end the year and ZEN as well Kabylake are coming out very soon.
CPU-i7 6700k O.C. 4.6Ghz-Motherboard-Asus z170-a-RAM-24gb DDR4-GPU-EVGA GTX 1080 FE-Case-Corsair 400c (white)-Storage-HDD: 2xWD Blue 1TB SSD: PNY SSDSC120GLC709B121-510 120GB-PSU-1000 watt coolermax-Display-ASUS VG248QE Black 24" 1080p 144 Hz -Cooling-Corsair H115i-Keyboard-G.Skill KM780 Cherry MX blues (Red backlight)-Mouse-Logitech G602-Sound-Logitech 5.1 z506
Need a budget headphone for under 100$? Sennheiser HD 558 Headphones
Got a Skylake CPU (k) Here is a guide to OC it!
https://linustechtips.com/topic/680393-450-build-list-help/#findComment-8753364
might get a strix 460
PC:
i5-6400
SEAGATE 2TB HDD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Mice:
Logitech G602
Logitech M330
Headset:
Logitech G430
https://linustechtips.com/topic/680393-450-build-list-help/#findComment-8753367
I would replace the APU with the newest Athlon(880k, no iGPU) and put the money towards getting a better GPU(Not saying the 460 is bad, just there are stronger cards out there.)
Current System: CPU - I5-6500 | Motherboard - ASRock H170M-ITX/ac | RAM - Mushkin Blackline 16GB DDR4 @ 2400mHz | GPU - EVGA 1060 3GB | Case - Fractal Design Nano S | Storage - 250GB 850 EVO, 3TB Barracuda | PSU - EVGA 450W 80+ Bronze | Display - AOC 22" 1080p IPS | Cooling - Phanteks PH-TC12DX_BK | Keyboard - Cooler Master QuickFire Rapid(MX Blues) | Mouse - Logitech G602 | Sound - Schiit Stack | Operating System - Windows 10
The OG System: I3-2370M @ 2.4 GHz, 750GB 5400 RPM HDD, 8GB RAM @1333Mhz, Lenovo Z580 Laptop (Ubuntu 16.04 LTS).
Peripherals: G602, AKG 240, Sennheiser HD 6XX, Audio-Technica 2500, Oneplus 5T, Odroid C2(NAS).
https://linustechtips.com/topic/680393-450-build-list-help/#findComment-8753370
why a10 when you're using an rx 460?
https://linustechtips.com/topic/680393-450-build-list-help/#findComment-8753462
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($110.99 @ SuperBiiz)
Motherboard: ASRock H110M-HDS Micro ATX LGA1151 Motherboard  ($49.98 @ Newegg)
Memory: Corsair Vengeance LPX 8GB (1 x 8GB) DDR4-2400 Memory  ($35.98 @ Newegg)
Storage: Toshiba 1TB 3.5" 7200RPM Internal Hard Drive  ($45.77 @ OutletPC)
Case: Cooler Master N200 MicroATX Mini Tower Case  ($34.99 @ Newegg)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($25.00 @ Newegg)
Other: Zotac gtx 1050ti mini ($139.99)
Total: $442.70
Generated by PCPartPicker 2016-10-25 09:45 EDT-0400
https://linustechtips.com/topic/680393-450-build-list-help/#findComment-8753502
Total: $442.70
This is what I'd recommend, especially since it will leave room to upgrade to Kaby Lake since it uses the 1151 socket.
"Better to be bad at video games than mad at video games" - BadAtVideogamesMan
https://linustechtips.com/topic/680393-450-build-list-help/#findComment-8753709
39 minutes ago, vtecf20c said:
i think there is a lot to change..
880k is cheaper than A10 and a litte bit faster
for 110 $ you can go for the I3 6100, in games it's A LOT faster than the 880K
and i will just wait the 1050ti, it's only 10$ more expensive, but  faster.
Total: $442.70
1 hour ago, belfouf said:
I should have mentioned that this build will have a elgato game capture pro pcie x1 card in it which needs i5 or equivalent minimum cpu
IM BACK BABY
https://linustechtips.com/topic/680393-450-build-list-help/#findComment-8753719
brah, an a10 7850k can't even beat a pentium sometimes, no way its an equivalent cpu to an i5.
https://linustechtips.com/topic/680393-450-build-list-help/#findComment-8753746
