  • 2 weeks later...
5 minutes ago, TasTyDK said:
this has nothing to do with resolution. im only asking about refresh rate
when you go surround you change your resolution for all monitors
example 3x1080p become 5760x1080 resolution
been surround user since came out
was short lived eyefinity user
before that used soft th
On 10/24/2016 at 9:08 AM, TasTyDK said:
Hi right now i have 3 60 hz monitors and im thinking about replacing 1 of my monitors with a 144 hz monitor. would the monitor still run at 144 hz even tho my other 2 monitors run at 60 hz?
thanks in advance
You can use multiple monitors with different refresh frequencies, they operate independently. However you will not be able to configure NVIDIA Surround or Eyefinity and span games across your monitors unless you set all the monitors to the same refresh frequency.
