Graphic card problem
Solved by bigneo,
2 minutes ago, Mrchaserx said:Havent checked, but when i touch it, its ultra hot
I wouldn't recommend touching hardware just like that. If Windows does not see your GPU then I would think there is something wrong with them rather than card or Nvidia drivers. Normally this kind of stuff with windows just works plug & play style.
There are quite few software to check hardware temperatures rather than touching them.
