     My computer has recently just started randomly rebooting into these reboot loops that just occur randomly. (Actually sometimes they occur when I crank up the settings on a game or run a stress test). I've tried everything but I still haven't found a answer.
Things I've tried:
1. Cleared CMOS
2. Re-installed Windows
3. Re-formmated my boot drive
4. Tried both of my RAM sticks by themselves
5. Changed the RAM slots from 2 - 4 to 1 - 3
6. Unplugged GPU
7. Unplugged my case fans
8. Took out the case power/reset pins
9. Tried Installing Ubuntu
My computer did update its BIOS by itself but I, as stated above, reverted it back.
please help
i5-8600K -  Asus Strix Z370E - Asus GTX 1060 Strix - EVGA 650W P2 - Samsung 970 Pro 500GB - G.Skill TridentZ 16GB
https://linustechtips.com/topic/679796-computer-randomly-reboots-into-loop-pls-help/
Whats cooling your CPU? Sounds like it shutting itself off due to heat. I've had the problem when I forget to plug in my pump for my AIO.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
Check for shorts on the mobo board standoffs. I saw a post recently where a guy had a broken stand off and was shorting the mobo
=======================Current Build=======================
Motherboard: ASUS Z170-AR
CPU: i5-6600k @ 4.5Ghz Overclocked
GPU: Gigabyte GTX980 @ 1200 Mhz Oveclocked GPU boost 1400Mhz
Memory: Corsair Dominator 16Gb @ 3200 Mhz
Cooler: NZXT Kraken x61
Storage: Corsair Force GS 128Gb + WD2TB + Seagate 1TB
PSU: Corsair HX650
Lighting: NZXT HUE+ with extension
Display: LG 34' Ultrawide 3440x1440
Peripherals: Razer Blackwidow x Chroma + Razer Firefly + Razer Mamba Chroma
Headphones: Astro A40 + Miniamp
Try stuff with the CPU, I think it´s probably where the problem is...
Take it out, clean the thermal paste, check for bent pins, install it and make sure everything is well seated, then make sure you install thermal paste and the cooler correctly and try again! good luck
I'm currently using an i3-6300 with the stock cooler.
Also, event viewer only states "The computer shut down without warning" and did not give any insightful info.
EDIT: AIDA64 says my CPU hovers around 85 degrees F during games and load. Is that normal?
