Help build my first pc !
Go to solution Solved by xephoneration,
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  (£174.99 @ Amazon UK)
Motherboard: MSI H110M PRO-D Micro ATX LGA1151 Motherboard  (£45.97 @ More Computers)
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR4-2133 Memory  (£43.90 @ CCL Computers)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  (£142.80 @ Novatech)
Video Card: MSI GeForce GTX 1060 6GB 6GB 6GT OC Video Card  (£238.99 @ Amazon UK)
Case: Cooler Master N300 ATX Mid Tower Case  (£32.75 @ Amazon UK)
Power Supply: SeaSonic ECO 430W 80+ Bronze Certified ATX Power Supply  (£45.99 @ Amazon UK)
Total: £725.39
Generated by PCPartPicker 2016-10-22 23:25 BST+0100
if you can deal with a windows 10 activate windows water mark for a bit sure! $25 over budget
I want to build my first Pc ! I want to use it for high level gaming and a bit of editing on Sony Vegas and Photoshop. My budget is around £500 but I could spend about  £700. I do not need a monitor or any other peripherals. I'm looking forward to seeing your suggestions. Thanks in advance. Feel free to ask any other information or questions.
https://linustechtips.com/topic/679469-help-build-my-first-pc/
honestly save up more. 300-400 is not gonna get you a whole lot. around 700-800 will get you something that is pretty good.
CPU-i7 6700k O.C. 4.6Ghz-Motherboard-Asus z170-a-RAM-24gb DDR4-GPU-EVGA GTX 1080 FE-Case-Corsair 400c (white)-Storage-HDD: 2xWD Blue 1TB SSD: PNY SSDSC120GLC709B121-510 120GB-PSU-1000 watt coolermax-Display-ASUS VG248QE Black 24" 1080p 144 Hz -Cooling-Corsair H115i-Keyboard-G.Skill KM780 Cherry MX blues (Red backlight)-Mouse-Logitech G602-Sound-Logitech 5.1 z506
Need a budget headphone for under 100$? Sennheiser HD 558 Headphones
Got a Skylake CPU (k) Here is a guide to OC it!
https://linustechtips.com/topic/679469-help-build-my-first-pc/#findComment-8740368
8 minutes ago, Abyss Gaming said:
yea 300-400 probably won't get you
Save up more
I've changed the budget to £500 - £700
Changed budget
https://linustechtips.com/topic/679469-help-build-my-first-pc/#findComment-8740389
Total: £725.39
https://linustechtips.com/topic/679469-help-build-my-first-pc/#findComment-8740413
Total: £725.39
Thanks. I may consider buying this build.
https://linustechtips.com/topic/679469-help-build-my-first-pc/#findComment-8740423
