Hello everyone
I'm gonna build my first gamer pc, so i would like to hear what you think about theese parts.
i already have a windows key and a CPU cooler.
CPU: Intel core i5 6600k
MB: Asrock z170A-x1
Ram : Crucial 16 gb ddr4 1x16 2133 MHz
GPU : Zotac gtx 1070 mini
PSU: Evga supernova 650w
HDD: Western Digital Blue 1 tb 7200RPM
SSD: Kingston ssd UV400 120 GB - Only for windows
Case: Bitfenix nova Midi-tower, ATX, mATX.
The total price is about 1200-1300$ US
https://linustechtips.com/topic/679426-need-help-first-build/
i suggest dual channel for better performance from your ram sticks. But i assume you are using one channel for upgradability.
corsair vengeance is a good choice. A part from that you have done a good job there man!
=======================Current Build=======================
Motherboard: ASUS Z170-AR
CPU: i5-6600k @ 4.5Ghz Overclocked
GPU: Gigabyte GTX980 @ 1200 Mhz Oveclocked GPU boost 1400Mhz
Memory: Corsair Dominator 16Gb @ 3200 Mhz
Cooler: NZXT Kraken x61
Storage: Corsair Force GS 128Gb + WD2TB + Seagate 1TB
PSU: Corsair HX650
Lighting: NZXT HUE+ with extension
Display: LG 34' Ultrawide 3440x1440
Peripherals: Razer Blackwidow x Chroma + Razer Firefly + Razer Mamba Chroma
Headphones: Astro A40 + Miniamp
https://linustechtips.com/topic/679426-need-help-first-build/#findComment-8739911
Like he said, dual channel RAM. 16GB of RAM would be plenty for you, no need for upgrading to 32GB. Also, I would try to get a full sized 1070. A mini card will likely see increased thermals and slightly lower boost clocks/overclocking.
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/679426-need-help-first-build/#findComment-8739919
32 minutes ago, Elthan Steel said:
Hello everyone
MB: Asrock z170A-x1
What GPU? A G2 Supernova or a G1?
https://linustechtips.com/topic/679426-need-help-first-build/#findComment-8739964
