1 hour ago, Kakapipi said:
My pc wont boot if my old hdd 250gb drive is connected.
What do you mean 'It won't boot'? Can you get into BIOS before and after POST? What error message is displayed? Are both drives SATA or is one IDE (given the size). Were both HDDs boot drives? :D
And yes, please don't start new threads with the same issue, it makes people not want to help you! Having read the previous thread, I would suggest using 'EasyBCD' to correct your problem!
Edited by Gordon Bennett
Juat realised the poster is posting the same issue on multiople threads!
https://linustechtips.com/topic/678771-boot-problems/#findComment-8733680
