Try to boot in safe mode (should be f8) if that doesn't work google your specific model number and see if you can initiate a reset process before it boots. I did that with my toshiba laptop. Of course doing this will result in you drive being formatted.
System: i7 4790K, Hyper 212 EVO, 16 GB Crucial Ballistix, GTX 1070 Super clocked, MSI Z97S SLI Krait Edition, Corsair RM 750, Corsair 750D (with 2 additional 140mm NZXT fans up top for exhaust.)
21 minutes ago, Trendwalker said:
-snip-
Could you give me more info please?
Is this a laptop or a desktop?
What do you have inside it?
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
11 minutes ago, Trendwalker said:
okay i tried safe mode nothing at all i will try a different monitor and looking up the model number as well
Can you get into BIOS?
Just to make sure, did you do the f10 key to attempt to get into bios? I think HP uses that shortcut.
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
