One of my hdd has failing reallocated sectors count, im using macrium trying to clone/image the bad hdd to a new hdd but keep getting error.
When i try to image i get an error saying "Backup aborted" Unable to read from disk, erro code 1117, The request can not be performed because of an i/o device error"
When i try to clone i get this  "clone failed , read failed 22-32"
please help
https://linustechtips.com/topic/678553-macrium-cloneimage-issues/
Please run a "chkdsk /f" from cmd.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
H: may not be an OS drive so it doesn't require a restart. Were there any errors that couldn't be fixed?
didnt read the whole summary................should i run it again? worry it would stress the hdd too much, should i also check scan and attempt to recover bad sectors option?
Even if it does stress the drive, it's better to check for the errors and correct if possible.
2 minutes ago, winkawak said:
Just finished, no problems were found im guessing it fixed it the first time so ima try to clone again.
I would start by just making a backup of the files you need.
This hdd is where i install all my games, cloning or imaging is only way for this games to work again.
Go for it. You can't re-download the games?
same tin
same thing failed at 7%
I would take the loss and re-download the games.
1 minute ago, winkawak said:
is windows 7 back up option same as cloning?
No. Have you tried Macrium on a different computer?
will it make a difference? Im the only one in the family uses a desktop.
It doesn't hurt.
There's AOMEI and Paragon Backup. I've found Macrium to be the easiest to use, but try those and see how it does.
imagining right now is at 8% with macrium normally it stopped at 3, lets wait and see. How do i use an image anyway? never done this
An image is essentially a compressed copy of the drive. You'll have to "clean all" the drive and then reload the image back to it.
what do you mean by "clean all the drive" ? format my new hdd to prepare for load image? how do i load image into new hdd?
If this is a storage drive, why are you wasting time imaging the drive?
Just stop writing to the faulty drive, and do a straight drag n' drop to a healthy drive.
