950 Pro M.2 Block
Go to solution Solved by Curufinwe_wins,
Gaming isn't going to come close to thermal throttling the 950 pro... Not that you will see any benefit anyways...
So I'm thinking about getting a 950 pro, but I am going to be running some heavy duty games on it. I know they tend to thermal throttle so I was wondering if anybody knew where I could find a water block? If I can't find a water block I will probably just put some ram heatsinks or some artic thermal pads on it.
https://linustechtips.com/topic/678406-950-pro-m2-block/
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/678406-950-pro-m2-block/#findComment-8729277
get a cheap ssd, you wont get any benefit from going m.2 or pcie
https://linustechtips.com/topic/678406-950-pro-m2-block/#findComment-8729322
15 minutes ago, TechnoFreak said:
Well I have a 850 pro and some load times are not as fast as i want so I wanted something faster
A 950 Pro won't fix that. Most game engines aren't meant to even come close to tapping out an SSD.
https://linustechtips.com/topic/678406-950-pro-m2-block/#findComment-8729379
