Themed Build - Need themed GPU
Go to solution Solved by TheRedViper,
The only thing I can think off relatively high end within your budget with a black/blue theme is either the MSI GTX 970 which has some versions with blue or the EVGA GTX 970
Hey there everyone!
I've come to you today for recommendations for a GPU for my black and blue themed build. I have a budget up $1,000 and I have already selected every part except for the GPU.
All the parts on my list are themed, including the cables, but I just need help in picking a black and blue GPU that will comply with my budget: http://pcpartpicker.com/list/mjB2kT
That leaves me with a maximum budget of $260 for a GPU. Maximum, but I need to spare every penny if possible.
https://linustechtips.com/topic/678332-themed-build-need-themed-gpu/
6 minutes ago, Van Diekon said:
Hey there everyone!
So far as i'm aware there aren't really any. you might have to settle for black with blue LED's. or maybe plastidip whatever you buy.
http://pcpartpicker.com/product/Pshj4D/evga-geforce-gtx-1070-8gb-ftw-gaming-acx-30-video-card-08g-p4-6276-kr
probably as close as you're gonna get... it has a little blue "ftw" badge on the side of it
CPU: Intel Core i9-10900K  MOBO: ROG MAXIMUS XII FORMULA GPU: 2080ti Hall of Fame 10th anniversary limited edition  PSU: Asus ROG THOR 1200W  COOLER: Optimus foundation black acetal RADS: 3x EKWB CoolStream PE 360  LOOP: EKWB torque HDC fittings / EKWB ZMT 15,9/9,5mm / EKWB CryoFuel Clear MONITOR: Acer predator X34
