Hi guys,
First ever forum post!
I decided to add an additional 970 to my existing Palit GTX 970 to my setup,
CPU: 5820K
RAM 16GB DDR4
GPU: GTX 970 - As mentioned.
MOBO: Gigabyte GA-X99-UD4
New 970 is a Evga 970.
I've tried 3 SLI bridges, no luck. The option for SLI is just grayed out.
I've used a DDU to remove all existing drivers and installed the cards one at a time on the new 373.06 driver.
Each card works perfectly fine on its own.
Google has failed me on this occasion.
Many thanks
Ben
https://linustechtips.com/topic/677755-help-cant-sli-970s/
Was the bois updated?
https://linustechtips.com/topic/677755-help-cant-sli-970s/#findComment-8723216
SLI is known to be picky after nVidia added a few more software limitations. It could be any one or more of these reasons
  • Different GPU clock frequencies -- make them both the same
  • Using the incorrect PCI-E X16 / X8 slots
  • (Hate it if it was this) Different manufacturer with different vBIOS -- same manufacturer with different vBIOS can also cause this problem!!
    • e.g. EVGA GTX 970 SSC + EVGA GTX 970 FTW
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/677755-help-cant-sli-970s/#findComment-8727660
