Here is hoping anyone can help :(
I currently got a triple monitor setup, which i wasnt really planing to but tried to do NVIDIA Surround on it, and found an issue once set, the resolution defaults to 3072x768 with no other options which then adds vertical bars to the middle monitor and i dont understand why is that. Tried a whole set of options, custom res before Surround, the thing is as soon as i get to surround it locks down to 3072x768 and cannot create or assign any other res.
Video Card: GTX1070
Monitors: Asus VN279Q - Asus PG279Q - Asus VN279Q (in that order) (I was expecting a 5760x1080 resolution and have the latest Nvidia Driver)
Connections: Using all 3 of the Display Ports on the GTX 1070
Google and I run out of ideas...
What say you :)
Thanks in advance
PC Gaming forever...
https://linustechtips.com/topic/677673-nvidia-surround-issue/
What I say? You've only got 1 set of eyes, and I could use one of them monitors... I know, not very helpfull. But this is all I've got. I only clone or drag'n drop my 2 (identical) monitors, using right-click on my desktop, screen resolution. (I can drag'n drop them in windows 7)
*EDIT: I never use the Nvidea software to change the layout of my screens. Always build-in windows screen configuration system thingy.
https://linustechtips.com/topic/677673-nvidia-surround-issue/#findComment-8721472
What cables were used? Any adapters? Are they all at the native res before enabling surround?
https://linustechtips.com/topic/677673-nvidia-surround-issue/#findComment-8725949
Thanks for the reply :)
All 3 monitors are using Display Port no adapters they all support DP as well as my GPU has 3 DP Ports.
Default Res for monitors is in this order: 1080p - 1440p - 1080p (the 1440p tried with native and also downing it to 1080p before enabling surround and nothing)
Weird fact is that if i only do 2 way surround then the i get the correct res ending in 1080p no matter which combination of 2 i use, so it starting to look like drivers maybe.
https://linustechtips.com/topic/677673-nvidia-surround-issue/#findComment-8726021
