1 minute ago, psychoboy69 said:
Ever since I installed a new cpu fan it's telling me when booting the computer cpu fan error go to bios now I've notice that it's also running on pretty low speed an antistatic brish could stop it what should i do
You could start by telling us the system specs/hardware and the make/model of your PC.
https://linustechtips.com/topic/677179-cpu-fan-error/#findComment-8715615
Here's everything you need to know plus one question should I keep xmp on?
You can leave it on, its fine. As for the fan thing, there should be options to change its speed, like where it says "Standard". My guess is that the fan error comes from the fan not spinning fast enough on boot.
https://linustechtips.com/topic/677179-cpu-fan-error/#findComment-8715646
Looks like the fan might be plugged into the wrong header. Look on the MOBO for the one marked CPU_FAN.
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
https://linustechtips.com/topic/677179-cpu-fan-error/#findComment-8715652
27 minutes ago, psychoboy69 said:
When i change the speed it does nothing I'll try changing a header
Just tried it it's already in cpu fan header
OK, what is plugged into CPU_OPT_FAN then?
Black Knight-
Daughter's Rig;
https://linustechtips.com/topic/677179-cpu-fan-error/#findComment-8715766
According to your BIOS, CPU_FAN in N/A (Not applicable), and CPU_OPT_FAN is the one running. Did you replace a 3 pin with a 4 pin or something?
Black Knight-
Daughter's Rig;
https://linustechtips.com/topic/677179-cpu-fan-error/#findComment-8715782
There's the fan thays right next the cpu gsn that is what connected there it isa 3 pinner so pne pin is out the monitoring for cpu fsn speed is off that is why its na but even when it's on it shows either na or really low speeds for a second and then back to na
https://linustechtips.com/topic/677179-cpu-fan-error/#findComment-8715799
If you could post a picture of the mobo and fan connection we may be able to help.
Black Knight-
Daughter's Rig;
https://linustechtips.com/topic/677179-cpu-fan-error/#findComment-8715967
Set it too ignore in bios. Does it on all my rigs.
https://linustechtips.com/topic/677179-cpu-fan-error/#findComment-8726927
Probably just a faulty fan. I would replace it and set the MOBO to ignore.
Black Knight-
Daughter's Rig;
https://linustechtips.com/topic/677179-cpu-fan-error/#findComment-8727160
