By using higher density disks and or putting more disks inside the drive.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/677040-how-are-larger-hdds-made/#findComment-8713951
1 minute ago, EminentSun said:
So i was just wondering, how do hard drive manufactures fit differing amounts of data (500gb vs 8Tb) on the same sized disk. A link to further reading would be much appreciated.
Platters platters and more platters xD
Main PC:
CPU: Ryzen 5 3600  | GPU: RTX 2060 | PSU:  | Memory: Corsair Vengeance RGB 3200Mhz 16GB | OS Drive: Western Digital Black NVMe 250GB | Game Drive(s): Samsung 970 Evo 500GB | Motherboard:  | Case: Fractal Design Define R6 | Monitor(s):  | Keyboard:  | Mouse: Steelseries Sensei 310
NASUS (NAS)
CPU: Intel Xeon X3440 | Motherboard: Super Micro X8SIL | Memory: 16GB DDR3 1066Mhz ECC UDIMM | HBA: Dell Perc H200 (Flashed to IT Mode) | Drives: 3x 16TB Seagate Exos x16, 2x 6TB Seagate Enterprise, 1x 6TB WD RED
RENEKTON (NAS)
CPU: Intel Core i5 4570TE | Case: Fractal Design Define S | Memory: 16G DDR3 1333Mhz SODIMM | HBA: LSI 1068E (Flashed to IT Mode) | Storage: 4x 3TB Hitachi, 2x 3TB WD RED
https://linustechtips.com/topic/677040-how-are-larger-hdds-made/#findComment-8713954
Hard drives have several platters inside (discs) , each with two surfaces. A hard drive has between 1 an 6-8 platters but anything above 4 is kind of difficult to make reliably and typically you'll see a lot of them only on more expensive enterprise drives (and the helium based drives for example, which can afford to put platters closer together as there's no air inside to complicate things)
So if you want a 500 GB drive, they may use 1TB platters, so you have only one platter inside but use just one read/write head, effectively using only one side of the platter to store data.  The same drive could be made to store 1 TB by adding a read/write head for the other side and by "formatting" the platter surface to hold data. A few minutes more in the factory to format the surface and change the firmware.
Some companies start manufacturing platters with higher densities of data in new factories while maintaining production in older factories which already made back the money invested in them. When this happens, entry level hard drives often start using those older generation platters and newer bigger hard drives would use the newer type platters. So for example, 400-500 GB drives could have two platters inside each holding around 300 GB of information, so they use 3 surfaces out of the 4 available to store data or something like that, while new hard drives would use 750 GB - 1 TB platters  (and that's also one reason why newer hard drives have faster speeds, in one rotation the head reads more bits due to information being more densely packed on the surface) .
Still it's a balancing trick, because the more platters inside the harder it is to balance them and calibrate the hard drive and extra read/write heads cost money, so the moment a new factory produces those new platters in volume with minimal rejects, the old platters are not cheap enough to be worth it.
https://linustechtips.com/topic/677040-how-are-larger-hdds-made/#findComment-8714001
