So i am working and a pretty small area where a fan cpu cooler and liquid cooler are not an option and was trying to find a very then cpu cooler/ probably be just a heat sink at this point for an FM2+ cpu. Any ideas? Also if there would be a way i could somehow hook my cpu and gpu up together so they can share same cooler (i.e. ill be using pci e riser on mini itx for gpu so i was wondering if i could like bend gpu over cpu and have them share same heat sink?)
https://linustechtips.com/topic/677036-cpu-cooler/
9 hours ago, Katsunaka said:
It's only 47mm tall, its designed to work in cases like the Node 202 and RVZ02.
So if it works in those tiny cramped cases, it'll work in yours with the fan.
It's the cooler I'm using on my Node 202 build.
 Well it is going in am xbox case
https://linustechtips.com/topic/677036-cpu-cooler/#findComment-8716465
