Hey guys I want to use a controller on my pc like an xbox or ps4 controller I have a ps3 controller but I have to use a usb and some software for it to work is there one I could use wireless?  thanks!
RIG: CPU: i7-5930K 4.5GHz GPU: EVGA GTX 980 TI Superclocked 6GB RAM: 16GB DDR4 Motherboard: Msi X99S SLI Krait Edition Storage: 128GB SSD 2TB HDD
https://linustechtips.com/topic/676235-controller-for-pc/
You can use Xbox One and Xbox 360 controllers wirelessly.
https://linustechtips.com/topic/676235-controller-for-pc/#findComment-8705477
do I have to connect a wireless usb or something?
https://linustechtips.com/topic/676235-controller-for-pc/#findComment-8705488
You can use their dongle or Bluetooth.
https://support.xbox.com/en-US/xbox-on-windows/accessories/connect-xbox-one-controller-to-pc
Edited by Godlygamer23
https://linustechtips.com/topic/676235-controller-for-pc/#findComment-8705494
https://linustechtips.com/topic/676235-controller-for-pc/#findComment-8705502
for the ps3 controller you can use motioninjoy. i've used such software myself and it worked out well. though i don't know if it has improved - or gotten worse - since then
and valve is bringing dualshock 4 support to Steam. not sure when though
https://linustechtips.com/topic/676235-controller-for-pc/#findComment-8705514
Yeah motionjoy sucks tbh
https://linustechtips.com/topic/676235-controller-for-pc/#findComment-8705620
33 minutes ago, johnny5c said:
do all xbox controllers need batteries? are there any that have rechargeable
https://linustechtips.com/topic/676235-controller-for-pc/#findComment-8705648
Microsoft does make some that are rechargeable.
https://linustechtips.com/topic/676235-controller-for-pc/#findComment-8705650
which are?
http://www.bestbuy.com/site/microsoft-xbox-one-play-charge-kit-black/9008298.p?skuId=9008298
That's for the Xbox One.
https://linustechtips.com/topic/676235-controller-for-pc/#findComment-8706086
