UE4 Sequence not running
Go to solution Solved by Cela1,
Nvm. I finally got it working - somehow changing it into a static mesh through the advanced brush settings made it work. I guess this is why I made this sandbox in the first place though ;)
So I have recently been messing around a bit in UE4 making a little sandbox area to test stuff. When I tried to make a sliding door for a building, the sequence for the door won't play. There are also hardly any sequencer tutorials as most show the older matinee feature from prior to 4.13.
Here is the viewport showing the sequence:
And here is the blueprint controlling the sequence:
What is even more confusing is that the second sequence (sfx) does play, while the first one does not! Please help :)
https://linustechtips.com/topic/676023-ue4-sequence-not-running/
https://linustechtips.com/topic/676023-ue4-sequence-not-running/#findComment-8705036
