You've paired a unlocked CPU with a motherboard that cannot overclock it. Plus, the power supply is overkill since 550W would be more than enough.
I'd also argue that not having a SSD in a build of this calibre is a sin.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/675937-first-pc/#findComment-8702350
8 minutes ago, Cameron17 said:
Im building my first gaming pc, is this a good build?
http://pcpartpicker.com/list/B4rXf8
unlocked processor but h110? o.O
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($227.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.88 @ OutletPC)
Motherboard: Asus Z170-E ATX LGA1151 Motherboard  ($103.98 @ Newegg)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory  ($41.99 @ B&H)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.49 @ OutletPC)
Video Card: Gigabyte GeForce GTX 1060 6GB 6GB G1 Gaming Video Card  ($259.99 @ Newegg)
Case: NZXT S340 (Black/Red) ATX Mid Tower Case  ($66.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($89.99 @ Newegg)
Total: $865.30
Generated by PCPartPicker 2016-10-15 06:04 EDT-0400
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/675937-first-pc/#findComment-8702358
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($196.88 @ OutletPC) don't get a 6600k without a z170 mobo.
CPU Cooler: CRYORIG M9i 48.4 CFM CPU Cooler  ($19.99 @ Newegg) same performance for less.
Motherboard: MSI CSM-H110M Pro-VHL Micro ATX LGA1151 Motherboard  ($51.39 @ B&H) can get the h110m-hds for $33 if you don't mind the looks.
Memory: Mushkin Redline 16GB (2 x 8GB) DDR4-2666 Memory  ($65.89 @ OutletPC) some newer games use more than 8gb iirc.
Storage: SK hynix SL308 250GB 2.5" Solid State Drive  ($64.99 @ SuperBiiz) store OS here.
Storage: Hitachi Deskstar 7K2000 2TB 3.5" 7200RPM Internal Hard Drive  ($46.00 @ Amazon)
Power Supply: Rosewill 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($59.99 @ Newegg) good enough for your needs.
Total: $832.11
Generated by PCPartPicker 2016-10-15 06:06 EDT-0400
https://linustechtips.com/topic/675937-first-pc/#findComment-8702367
Any motherboard recommendations?
https://linustechtips.com/topic/675937-first-pc/#findComment-8702389
The ASRock Z170A-X1/3.1 goes for $55 on Newegg if you use the rebate and the promo code EMCFEFT27.
https://linustechtips.com/topic/675937-first-pc/#findComment-8702395
1 minute ago, Cameron17 said:
I'm  was trying to get all my parts from one site, is it on amazon
On Newegg only.
Why are you trying to buy all your parts from one site? You can save some cash by buying from multiple retailers.
https://linustechtips.com/topic/675937-first-pc/#findComment-8702404
On Newegg only.
Is this good? https://www.amazon.com/ASRock-MicroATX-Motherboard-Z170M-EXTREME4/dp/B017NMX6JO/ref=as_li_ss_tl?s=pc&ie=UTF8&qid=1475124168&sr=1-1&keywords=ASRock+Z170M+Extreme4&linkCode=sl1&tag=techsource02-20&linkId=1e2bac17eaa42890651dcd7061cae2ac
https://linustechtips.com/topic/675937-first-pc/#findComment-8702418
https://linustechtips.com/topic/675937-first-pc/#findComment-8702426
2 minutes ago, Cameron17 said:
Pc part picker said it's compatible.
It is. But typically ATX motherboards look nicer in ATX cases.
https://linustechtips.com/topic/675937-first-pc/#findComment-8702431
PCPartPicker part list: http://pcpartpicker.com/list/xywZQV
Price breakdown by merchant: http://pcpartpicker.com/list/xywZQV/by_merchant/
Motherboard: ASRock Z170A-X1/3.1 ATX LGA1151 Motherboard  ($57.99 @ Newegg)
Storage: Crucial MX300 275GB 2.5" Solid State Drive  ($69.95 @ SuperBiiz)
Video Card: MSI GeForce GTX 1060 6GB 6GB 6GT OC Video Card  ($249.00 @ B&H)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($74.99 @ Newegg)
Total: $858.38
Generated by PCPartPicker 2016-10-15 06:51 EDT-0400
https://linustechtips.com/topic/675937-first-pc/#findComment-8702449
