How do i read CPU temperatures
Solved by darkwizard06,
If the software you are using is actually outputting a correct cpu temperature, then get the average of all cores, then that is your average cpu temperature.. Don't add them all.
5
1
toxic_worper ·
7
1
voltigeurramon ·
Posted in Troubleshooting2 -
1
1
