cpu fluctuates between %77-%93 each core stays at about 73 degrees %85-%94 usage each core the 2.6ghz holds
about 5gb of the ddr2 is used
gpu1 fluctuates between %35 the spikes back to 90s gpu stays in the 50s in temp
my specs are
q8300 2.6ghz
8gb dddr2
rx460
https://linustechtips.com/topic/674347-bottle-neck-help/
1 hour ago, masterkickass7 said:
cpu fluctuates between %77-%93 each core stays at about 73 degrees %85-%94 usage with the ocasional drop in to the mid 70s each core the 2.6ghz holds
my specs are
q8300 2.6ghz
8gb dddr2
rx460
https://linustechtips.com/topic/674347-bottle-neck-help/#findComment-8684936
1 hour ago, NumLock21 said:
Your PC is consider old
yes i know
https://linustechtips.com/topic/674347-bottle-neck-help/#findComment-8684947
Then what's with the 6700K in your sig?
friends starter pc
https://linustechtips.com/topic/674347-bottle-neck-help/#findComment-8684956
