keep in mind everything is in AUD
So I am creating my first PC with a max price of $2050, this is including the $500 I have put into peripherals n monitor. Please leave suggestions for what you recommend I change in order to save more money/get better performance/look more aesthetically pleasing. I will be using the PC for gaming, recording and light editing. ALL PURCHASES WILL BE THROUGH MWAVE SO PLEASE MAKE SURE YOU BROWSE THE SITE FOR COMPONENTS AS IM VERY UNLIKELY TO BUY ANYWHERE ELSE DUE TO CONVENIENCE
PC Related Parts
Crucial Ballistix Sport LT 16GB (2x 8GB) DDR4 2400Mhz Memory $115
Gigabyte GeForce GTX 1060 WINDFORCE 6GB Video Card $420
Seagate ST1000DM003 1TB BarraCuda Desktop HDD 3.5” 7200RPM SATA3 Hard Drive $70
Gigabyte Z170N-Gaming 5 LGA1151 Mini-ITX Intel Motherboard $250 (Definitely needs to change. Must have at least 3 usb ports)
Corsair Carbide Clear 400C ATX Windowed Mid-Tower Case - Black $150
Thermaltake SMART 650W 80Plus Bronze Power Supply $110
Intel Core i5 6500 Quad Core LGA 1151 3.2 GHz CPU Processor $275
Deepcool Gamer Storm Maelstrom Lucifer K2 PWM Fan Multi-Socket CPU Cooler $55
(am trying to keep the price at around what it is, please recommend stuff ending out at below $1500 AUD and anything that would cost above my budget for the pc itself so I can upgrade as time goes by!)
Monitor
ASUS VX239H 23" Full HD AH-IPS LED Monitor - Black $230
Accessories
Razer Mamba Chroma Wireless Gaming Mouse $200
Razer Goliathus Extended Control Gaming Mouse Mat $35
In regards to keyboards I accidently purchased two Deathstalker Chromas a while back, one is still in the box untouched and so I wont be needing to purchase a new one for at least 4years.
I am open to any suggestions and as I do not have much knowledge on computers I would appreciate all help possible to offer the best performance for FPS games such as CS:GO.
I did put a lot of time and research into this and will be purchasing and building within the next 2months :) I will update the post as I progress.
https://linustechtips.com/topic/674063-need-help-choosing-components/
17 minutes ago, ObliviationGNx said:
Get an Unlocked CPU if you wanna pair it with a Z series mobo.
"Z series mobo" ? Sorry, & what do you mean by unlocked, I am not very experienced.
8 minutes ago, MrDrWho13 said:
You'll also want an SSD - maybe just like a 250gb one for Windows and your programs since this will be a massive improvement to your user experience.
https://www.mwave.com.au/product/corsair-force-le-240gb-25-sata-iii-ssd-cssdf240gbleb-ab81093 is one i found
But what does it do? I don't want to be spending unnecessary money here but will take your word for it, I completely forgot about the installation of windows too which will be $140, do you have any idea on a cheaper motherboard so I can afford the SSD without any problems?
47 minutes ago, MrAwesomepants said:
Do you really want the wireless mouse? The mamba tournament edition is wired but is cheaper
I have changed the the Tournament and decided to also purchase a Razer Sieren, I really dont care what people have to say about the mic, I like it, I've seen the comparisons and I am going to get it. Do you have a recommendation on a ssd?
I browsed through the shop and it seems like the crucial mx300 275 GB ssd is a great choice. Recently had a friend whos 750 EVO failed on him
Sweet, I'm now confident that I have finalised this setup coming in around 2200aud, will make a update post vry soon.
Does this mean I will need a harddrive and SSD ? If only an SSD replaced the hd
You can use just an SSD, but you'll get better value for money with both since HDDs are cheaper per GB but SSDs have much better performance. By having both, you won't compromise on storage space, and your computer will boot and load much much faster.
Windows 10 supports having multiple storage devices. Here's my guide on setting them up: https://linustechtips.com/main/topic/629590-windows-10-wont-reset/#comment-8131454
I edit my posts a lot.
Z series and unlocked CPU (models with K at the back e.g. 4770K) allows you overclock your CPU which will lead to faster performance. If you're not gonna do overclocking, i would suggest you to get motherboards with either B or H in front E.G. B170 or H170
I may upgrade in the future so im getting a z
Why on earth waste 200 bucks on a wireless mouse. You can get 50 dollar wired versions that are just as good or better, and they're likely to have better latency as well.
The same goes for expensive keyboards for that matter; it's great if you have money to burn but when it requires concessions to the specs of the computer itself I personally wouldn't do it.
Given that you're already putting in the money for a Z-motherboard I'd also consider paying the 50 rubles extra for a 6500k (or as mentioned cheaping out on a motherboard as well).
And as everyone else said, definitly get an SSD, and preferably at least 250 GB if you want some bang for your buck (the 120s now are relatively overpriced). Buying a new pc now without one is like getting a Ferrari with wooden wheels.
