So I'm building a raspberry pi retropie machine that emulates a bunch of different systems so I wanted a good controller. The best controller the PS4 controller. But what I'm asking is if I can plug in the charging cable to the controller and use it as if it were wired. I don't want to use the built in bluetooth or buy a dongle for that matter. Please and thank you, any help is accepted.
https://linustechtips.com/topic/673358-ps4-controller-question/
This is much better than motion joy imo https://inputmapper.com
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
https://linustechtips.com/topic/673358-ps4-controller-question/#findComment-8676099
Yes the cable for PS4 transfer data as well as power.  Though by default the PS4 controller has no drivers for windows so you need another program to emulate it into a xbox controller, whether something like that is available for raspberry pi I don't know.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/673358-ps4-controller-question/#findComment-8676546
