Specs:
FX-6350 OC'd to 4.4GHz (Stock Voltage)
Sapphire R9 280X Dual-X
8GB G.Skill SNIPER RAM
Corsair CS650M PSU
Windows 7 Pro 64-bit
I recently got the sapphire r9 280x and for a short while it seemed to play fine. never had any issues. played atleast 20 hours of Witcher 3 at almost max settings with hairworks turned off, and havent had any issues with it. All of a sudden this weekend ive noticed that anything i play i get consistant frame rate drops, stuttering, driver crashes, etc. I starting having this on Windows 10 but i just freshly installed Windows 7 and the problem followed suit. ive ran memory tests to ensure its not anything RAM related and all is well there. Is this some driver issue or is something causing my card to die?
https://linustechtips.com/topic/673111-r9-280x-issue/
6 minutes ago, Lonewolf33651 said:
Specs:
Corsair CS650M PSU
When that happened to me I did the old unplug your computer from the wall, wait 15 minutes, and then plug it back in. That worked for me, but I don't know if it will fix your problem. Hope I could help!
https://linustechtips.com/topic/673111-r9-280x-issue/#findComment-8672385
Have you checked to see what your temperatures are? If you don't already have it, download and install GPUZ. Use the "sensors" tab to monitor clock speed and temperatures while gaming and you will most definitely find what is causing the frame drops.
|| i7-8700k @ 4.9GHz || Asus Z370-i || HyperX Fury 32GB @ 2400MHz || Nvidia Titan Xp || 500GB Samsung 950 Pro || Deepcool Captain 240 RGB white || Phanteks Enthoo Evolv ITX Glass || InWin Aurora fan kit || Corsair RM750x white || Ensourced Customs sleeved extensions || Tesoro Gram Spectrum white || Logitech G603 ||
https://linustechtips.com/topic/673111-r9-280x-issue/#findComment-8672396
