Just now, iKl9kca said:
RX 460 2Gb no six pin needed
Drivers installed?
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/672986-gpu-help/#findComment-8671084
Previous card was the 7450 is it still needed since it's AMD, I mean wouldn't I still get a display output
OK sorry, I misread it as 740 (Nvidia card). Are there any other computers you can try your GPU on?
https://linustechtips.com/topic/672986-gpu-help/#findComment-8671092
11 minutes ago, iKl9kca said:
Nah it wasn't the issue was it was a x8 and my mobo is sandy bridge and didn't support it
Radeon HD 7450 and RX-460 uses different GPU drivers.
The Radeon HD 76xx (and below) and older graphics card are now moved to the "Legacy" support category.
Those drivers are different from the 7800 series up, and newer -- like your RX-460.
  1. Put your Radeon HD 7450 back inside your computer
  2. Uninstall your existing drivers
  3. Turn off computer and swap in your RX-460
  4. Download and install the latest drivers for your RX-460 DIRECTLY from AMD's website
The latest available currently should be driver version 16.10.1.
Dated: October 4, 2016.
Next own down is version 16.9.2.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/672986-gpu-help/#findComment-8671653
26 minutes ago, n3rdyknowit said:
Currently have a ASUS GTX 650 with 2gbs of VRAM, should I upgrade?
Please start your own question thread; don't hi-jack another forum user's.
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/672986-gpu-help/#findComment-8672600
Hi! Welcome to the ltt forum!
This is not rly the place to ask that. Try starting your own topic! Then people can see you have a question. And yes, you should upgrade ^^
I5 4440//8gb Corsair Vengeance ddr3//Sapphire Radeon r9 380 4gb//ASUS h81m-plus//WD caviar blue 1tb//Cooler Master N200//Cooler Master G500
https://linustechtips.com/topic/672986-gpu-help/#findComment-8672603
