a family member gave me there old pc and all i had to do is get some family pictures off the psu was dead put another one in and then i found out the mobo is dead I put the hardrive in a spare pc and it jumps to bios and won't detect the hdd it's spinning any help
https://linustechtips.com/topic/672533-harddrive-help/
Do you have the SATA cable attached firmly?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/672533-harddrive-help/#findComment-8666727
it's ide
https://linustechtips.com/topic/672533-harddrive-help/#findComment-8666728
Is the harddrive SATA or IDE?
If IDE: there is a jumper pin you need to set as master if you want to run windows off of it or slave if you want to view it like a secondary drive.
if SATA: go into your bios and set the boot priority to your HDD and restart
https://linustechtips.com/topic/672533-harddrive-help/#findComment-8666734
Once you enter windows, search for "disk management" (or the equivalent in your language) In disk management, you need to assign a drive letters for the partitions on the drive. Once you've assigned letters, they'll be visible in file explorer like your other drives.
Take note of the partition sizes. There should be one or two partitions that are very small, a few hundred Megabytes. Don't assign letters for those partitions. Just the ones with data on them.
https://linustechtips.com/topic/672533-harddrive-help/#findComment-8666739
it won't boot windows
https://linustechtips.com/topic/672533-harddrive-help/#findComment-8666741
2 minutes ago, masterkickass7 said:
it's ide
Do you have the pins for "master" in place? Have you checked Disk Management in your computer? Can you boot into Linux?
https://linustechtips.com/topic/672533-harddrive-help/#findComment-8666745
OK. It's probably trying to boot off of the secondary drive. In BIOS, make sure your own drive is the primary boot device. If you have AHCI enabled, you can also plug the secondary drive in after you've entered Windows. Without AHCI, it has to be plugged in during POST.
https://linustechtips.com/topic/672533-harddrive-help/#findComment-8666749
do u mean the blue ribbon ide cable
https://linustechtips.com/topic/672533-harddrive-help/#findComment-8666776
1 hour ago, TiberiusMoon said:
it's supposed to cover two there is cover on the second row
https://linustechtips.com/topic/672533-harddrive-help/#findComment-8666795
