High temps
Go to solution Solved by Thorimus,
1 minute ago, Mountaingoat48 said:
The tubes are hot near the CPU and normal towards the radiator. How do I get the pump to work?
Make sure that all the cables that should be plugged in, like power for the pump, are plugged in. Take a look at this to make sure: http://www.corsair.com/en/blog/2013/february/how-to-install-the-hydro-series-h100i-cpu-cooler
I just built my computer with a 6700k, h100i, and Asus Maximus 8 Extreme motherboard. I go into the bios and my CPU temps skyrocket up to 75 degrees. I made sure that the cooler was plugged in and it was making good contact. I just can't seem to figure out why this is happening. Help.
https://linustechtips.com/topic/672476-high-temps/
there is thermal paste applied? sufficient mounting pressure.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/672476-high-temps/#findComment-8666127
Are the fans on the AIO spinning and is the pump working? You can try feeling the tubes, the temperature should be pretty much the same throughout them. If they're very hot near the CPU and normal near the radiator your pump isn't working.
“sufficiently advanced technology is indistinguishable from magic still going to require driver rollbacks when it stops working for no reason“
https://linustechtips.com/topic/672476-high-temps/#findComment-8666140
https://linustechtips.com/topic/672476-high-temps/#findComment-8666160
