help with payday 2
By
Rodriguez198
in PC Gaming
in PC Gaming
Solved by LightDust,
Try looking through this. It's a master list of Payday 2 fixes. http://steamcommunity.com/app/218620/discussions/0/864975632555749187/
It apparently is a common problem. You will most likely have to go through each attempt that fit your problem.
Another one is try switching resolution and see if it helps.
DARTHDIVIDER0213 ·
Posted in Troubleshooting5 -
Xx-albinos-xX ·
Posted in Troubleshooting10 -
2
_Darasuum_ ·
Posted in Power Supplies6 -
1
4
anothertealtiger ·
Posted in Programs, Apps and Websites2 -
Mumintroll ·
Posted in Programs, Apps and Websites4 -
ElDTac ·
Posted in CPUs, Motherboards, and Memory3
play_circle_filled
Latest From ShortCircuit:
