Specs? Nice build by the way!  This chassis always intrigued me
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
I absolutely love that cast M/B plate on the D Frame. :wub:
I could do without the stickers, but that's just my personal taste.
Would it be possible to route the two tubes going to the res/pump through the
narrower case side instead of between the window and the frame? I think that
might look cleaner (at least to my eyes), but it's tricky to tell if it can
be done from here.
But nice, definitely something different for a change. :)
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
i tried running the tubes from the other side but the top tube stopped the top fan from spinning. i wanted it to go in from the other side but this was the compromise.
i7 3770k
MSI motherboard
GTX 660
alphacool rads
koolance CPU Block
bitpower pump mod
XSPC photon 270 glass res/pump combo
monsoon fittings
EK gtx 660 water block
corsair SP 120 fans
corsair PSU AX 850
WD blue 1T
corsair SSD 120GT (on the back)
I like the MSI gaming shield badge but yeah, stickers are a bit gay really. I've put all mine in a baggy lol.
Lovely build though. I've always had a soft spot for the D frame. Reminds me of a roller coaster construction kit :D
Area 51 2014. Intel 5820k@ 4.4ghz. MSI X99.16gb Quad channel ram. AMD Fury X.Asus RAIDR.OCZ ARC 480gb SSD. Velociraptor 600gb. 2tb WD.
Ah well, sometimes you have to compromise. Still a nice build. :)
The mechanical engineering geek side of me absolutely loves the D frame. I don't
really like its aesthetics so much, but more the constructional concept and materials
used.
Those Monsoon fittings look great. Nice job. Love how the tubing is the ~same colour as the frame.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
Specs????
i7 3770k
MSI motherboard
GTX 660
alphacool rads
koolance CPU Block
bitpower pump mod
monsoon fittings
corsair SP 120 fans
corsair PSU AX 850
WD blue 1T
The monsoon fittings look beast. I've been waiting for someone to use them in a build. I plan to do so in the future aswell
Corsair 600T White | Gigabyte Z77-UD3H | Intel Core i5-2500k | 8GB Gskill Ares@1600MHz | Gigabyte G1 GTX970 | OCZ ZT 550 | Western Digital Caviar Blue 500GB | Western Digital Caviar Black 1TB | Samsung 840 EVO 250GB (boot) | Full Custom Loop | NZXT HUE
 the monsoon fittings look really good but they can be a bit hard to screw on sometime if you cant get your hand in the right place to get some leverage on it.  but well worth the buy
I will use them in the distant future
Loving the xspc photon pump res, I'm planing to use that in my build soon too! Love the fittings also! Nice build man!
Build log
CPU: FX-6100 @ 3.9 MOBO: GA 990XA-UD3 RAM: Corsair Vengeance 8GB GPU: HD6870 PSU: Corsair GS800 Case: Bitfenix Outlaw SSD: Samsung 840 250GB HDD: Seagate Barracuda 1TB Cooling: Custom Water-Cooling Peripherals: Keyboard: G710+ Mouse: Steelseries Sensei Steering Wheel: Logitech G27 Sound: Speakers: Logitech x530 Headset: Razer Chimaera Monitor: Benq G2450HM, LG 32" TV
  • 1 year later...
