34 minutes ago, Vape_lord said:
hello,
i am going to build a new pc (white) 1st ofall is it a good pc? and is there a good white cooler that you recommend?
this one
http://pcpartpicker.com/product/LWbkcf/enermax-cpu-cooler-etst40fw
or
http://pcpartpicker.com/product/mjdqqs/phanteks-cpu-cooler-phtc12dx
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/671795-new-white-build-help/#findComment-8658806
