Looking for Nas Solution
I've used several models of Synology for a few small businesses I've helped setup NAS for. The Synology is certainly the way to go in terms of the great OS, Disk Station Manager. It rocks. Plenty of features, constantly updated, and very easy and powerful to manage from the admin side of things. DiskStations tend to have very low power consumption and also don't take much space compared to some custom server build which can take more power and physical space if you're not careful.
I've heard great things regarding FreeNAS if you want to do it yourself, just make sure that the long-term power consumption doesn't secretly drive up the cost of operation. For a simple two disk NAS, I think you're better off with Synology because you get the great DSM. If you needed to build a huge array of storage and wanted to drive down costs, then I would suggest looking more into FreeNAS or unRAID just to give yourself the power without the big-time cost of the larger Synology systems.
