HDMI Cable not using correct resolution.
I've recently tried to use a HDMI cable into my TV instead of using a VGA and i noticed that the HDMI cable wont display the TV's max resolution correctly (1920x1080) i have to reduce the resolution for the whole screen to be seen, if i dont it cuts off the sides. Can anybody explain to me why this could be?
CPU Intel i7-6700k | Motherboard ASUS Maximus Hero VIII | GPU MSI GTX 970 | RAM 16 GB Corsair Vengeance 3000Mhz | Cooling Noctua NH-D15 | Storage 240GB Crucial M500; 2TB Seagate Barracuda | PSU EVGA 850w | Case Phatek Enthoo Pro M Acrylic
https://linustechtips.com/topic/6711-hdmi-cable-not-using-correct-resolution/
So your trying to connet your computer to your TV with a HDMI cable?
Yes
If you have an AMD video card go into Catalyst and search for Scaling Options, set it to 0.
I have a Nvidia graphics card
So your trying to connect your computer to your TV with a HDMI cable?
Yes i am
Yer it cuts of the sides for some reason :S
Lets see, maybe you have the zoom option on your tv, try them out, maybe it is that.
Do you have other hdmi display to try if it is the computer?
I dont have any other displays :/ it also doesn't display words as clearly as a VGA cable does.
