8 minutes ago, DeViL-- said:
need a 800$ usd pc build please ty. if possibble with amazon links sorry for asking for much.
what is the purpose of this PC? do you need more than just the tower (monitor, peripherals, OS, etc)? do you prefer future upgrade ability or raw performance now?
https://linustechtips.com/topic/671062-help/#findComment-8651214
CPU
Intel Core i5-6600K 3.5GHz Quad-Core Processor
$237.49$8.11$245.60Amazon (Overridden)BuyCPU Cooler
Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
$27.97$9.31$37.28Amazon (Overridden)BuyMotherboard
MSI Z170A SLI ATX LGA1151 Motherboard
$97.99$9.42$107.41Amazon (Overridden)BuyMemory
Crucial Ballistix Sport LT 8GB (2 x 4GB) DDR4-2400 Memory
$39.99$8.15$48.14Amazon (Overridden)Buy
Add Additional Memory
Storage
Western Digital Caviar Blue 320GB 3.5" 7200RPM Internal Hard Drive
$20.50$8.65$29.15AmazonBuy
Add Additional Storage
Video Card
Gigabyte Radeon RX 480 8GB G1 Gaming Video Card
$269.00$9.49$278.49Amazon (Overridden)Buy
Add Another Video Card For 2-Way CrossFire
Case
Raidmax ATX-295WBP ATX Mid Tower Case w/500W Power Supply
$46.07$15.49$61.56Amazon (Overridden)Buy
Base Total:$739.01
Shipping:$68.62
Total:$807.63
https://pcpartpicker.com/list/#incompatibilities
https://linustechtips.com/topic/671062-help/#findComment-8651261
16 minutes ago, DeViL-- said:
for gaming mostly
I would have recommended something very similar to @PCNoobie's build. you might want to play around with the storage options and case option (depending on what it is you want) if you have additional budget, but there's nothing wrong with the ones chosen and I've even recommended them to others in the past. he has recommended a pretty solid build for your needs
@JJS76's build looks tempting on the surface as well, but the PSU/case combo is very worrisome and I wouldn't recommend it. also it has terrible storage capacity and its all a HDD. not really ideal. an RX480 8GB is also a slightly worse GPU to the 1060 6GB. his build sacrifices a lot to get that 6600k in your system and if you're only gaming at 60 fps then the i5-6600k will make no performance difference compared to an  i5-6500. I would not recommend getting this suggested build.
https://linustechtips.com/topic/671062-help/#findComment-8653365
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($197.88 @ OutletPC)
Motherboard: ASRock H170A-X1 ATX LGA1151 Motherboard  ($76.98 @ Newegg)
Memory: Mushkin Redline 16GB (2 x 8GB) DDR4-2666 Memory  ($65.89 @ OutletPC)
Storage: SK hynix SL308 250GB 2.5" Solid State Drive  ($64.99 @ SuperBiiz)
Storage: Toshiba 1TB 3.5" 7200RPM Internal Hard Drive  ($45.77 @ OutletPC)
Video Card: Gigabyte GeForce GTX 1060 6GB 6GB WINDFORCE OC 6G Video Card  ($239.99 @ Newegg)
Case: Deepcool DUKASE V2 ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($39.99 @ Newegg)
Total: $781.48
Generated by PCPartPicker 2016-10-05 02:38 EDT-0400
https://linustechtips.com/topic/671062-help/#findComment-8653829
Here's a list with amazon prices you like you asked. Go to the part link and click the Amazon logo and it'll take you there.
PCPartPicker part list
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($204.00 @ Amazon)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($53.99 @ Amazon)
Memory: Corsair Vengeance LPX 8GB (1 x 8GB) DDR4-2400 Memory  ($39.99 @ Amazon)
Storage: PNY CS1311 240GB 2.5" Solid State Drive  ($64.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Amazon)
Video Card: EVGA GeForce GTX 1060 6GB 6GB SC GAMING Video Card  ($259.99 @ Amazon)
Case: Thermaltake Versa H25 ATX Mid Tower Case  ($39.99 @ Amazon)
Power Supply: Corsair CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.99 @ Amazon)
Total: $772.93
Ignore the $850 total when you go to the partpicker list since the shipping would be free.
  • Quote people's post else they won't know you replied.
Crapware | 4670k | Hyper212X | GSkill RipjawsX 16GB | Sapphire R9 280x VaporX | 840EVO 120GB | 1TB BLACK + BLUE
Logitech G102 | Corsair K70 MX Brown | HyperX Cloud
https://linustechtips.com/topic/671062-help/#findComment-8654934
