Hey i am currently looking for a new keyboard.
I want a mechanical keyboard.
It should be full sized, have dedicated media keys preferably with a volume weel and backlighting.
I would also like some macro keys and a good software to programm the keys.
I do not need something like fancy RGB lighting.
If possible it should also come with a wrist rest.
The keyboard should cost not mutch more than 100 euro.
I already considered the g710, as it seems to fit my preferences well, but it sadly does not seem to be available here.
https://linustechtips.com/topic/671027-mechanical-keyboard-help/
Logitech is the way to go with what you've described. Switch preferences?
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/671027-mechanical-keyboard-help/#findComment-8650806
9 minutes ago, julian1811 said:
I do not realy have a switch preference, maybe a mx brown but i would also take something else if the rest is good. I also took a look at the logitech g610, but i am realy missing a wrist wrest there and it also does not have macro keys.
why do you need macro keys if i may ask?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/671027-mechanical-keyboard-help/#findComment-8650874
