trying to build a computer, the gpu is getting power the pc its self is not turning on, please help
Update:
I fixed the problem, I got a new motherboard but when I was putting it together again I felt like an idiot because I had the CPU power cord flipped the wrong way...
CPU- Ryzen 9 3900x
CPU Cooler- Artic Liquid Freezer 2 240mm
GPU-  GIGABYTE AORUS GeForce RTX 3070 Ti Master 8G
RAM- CORSAIR VENGEANCE RGB PRO 32GB 3200Mhz
PSU- Cooler Master MasterWatt 650 Watt
HDD- WD Blue 4TB x2
SSD- 1TB WD Blue SN550 NVMe
Case- Custom Made Desk
Motherboard- ASUS ROG Strix B450-F Gaming
Microphone- Blue Snowball Ice
Headphones- Razer Nari Ultimate
Webcam- Logitech c270
Monitors- MSI Optix MAG24C and Acer KA240HQ Abid
Mouse- Corsair Nightsword RGB
Keyboard- Corsair K95 RGB Platinum MX Speed
https://linustechtips.com/topic/670661-computer-build-help/
Just now, I_IHaveNoLife_l said:
Have you tried taking the GPU out and using the normal display on the MoBo? Are there error lights on the MoBo?
The light on the GPU turns on and there is no lights at all on the motherboard
CPU- Ryzen 9 3900x
HDD- WD Blue 4TB x2
https://linustechtips.com/topic/670661-computer-build-help/#findComment-8646824
Are the 8-pin and 24-pin power connectors connected? What specs are we talking about? New or used parts?
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/670661-computer-build-help/#findComment-8646837
I am using this build
all new parts (besides the gpu) I am using a different power supply and different GPU than in the video
CPU- Ryzen 9 3900x
HDD- WD Blue 4TB x2
https://linustechtips.com/topic/670661-computer-build-help/#findComment-8646849
The GPU lights turn on but the case's power button isn't doing anything neither is the LED's on the case. Yes I made sure the pins are correctly in (with the positives and the negatives)
CPU- Ryzen 9 3900x
HDD- WD Blue 4TB x2
https://linustechtips.com/topic/670661-computer-build-help/#findComment-8646876
