44 minutes ago, mecman00 said:
I know that the socket type of a CPU matters however if I wanted to change from a Haswell  CPU to Devils Canyon CPU would that be a problem
If you want to go from a 4670k or 4770k to a 4790k you don't need a new motherboard. Devil's Canyon is still Haswell, it's still LGA1150. Z87, H87 and H81 boards almost universally support the DC release chips with proper BIOS updates.
If you want a Haswell-E chip like the 5820k then you need a new motherboard, specifically an X99 LGA2011 v3 board and DDR4.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/670268-cpu-help/#findComment-8642638
