HD 7990 CrossfireX GPU Usage Problem
Go to solution Solved by Wolfur,
The other games are Dishonored, Crysis 3, Crysis 1, Battlefield 3, Metro, Skyrim etc. Most of them have a crossfire profile.. so i think i buy in the bottleneck.. just googled it and, yeah. AMD's pretty bad...
so what should i go with? a i5 4440, a i5 4670K or even a i7 4770k to not bottleneck the Card?
If you don't want to overclock, get:
Xeon e3-1230v3 - it's i7 4770 with different name and without integrated GPU.
some motherboard, like MSI H87-G43.
if you want to overclock, get i5 4670k or 4770k (depending on how much money you have, i7 will be a bit better)
Z87 motherboard for example MSI Z87-g45 Gaming or MSI Z87-G55.
Hi all,
i recently bought a 7990 for a damn good price (500€) but unfortunately i do not get full usage in every game. Mostly it is around 20-40% per GPU. One Exception: Tomb Raider! There i get full GPU Usage (90-99%) and the friggin high FPS.
I have tried everything... Disabling ULPS -> no difference, forcing another Crossfire profile -> no difference.
Tried different drivers.. Currently at the 13.11 Beta
Clocks of the GPUs are slightly overclocked -> 925MHz to 1GHz
PowerLimit is on +20%
I use Afterburner OSD to evaluate the Usage.
My System:
AMD FX 8120 @ 4 GHz
Crosshair V Formula
HD 7990 (PowerColor non-reference) This one
be quiet Power Zone 850W PSU
Please help me out  :blush:
Personal rig: Silverstone SG13 Case | AMD Ryzen 1700 | Biostar X370GTN |  EVGA GTX1080 Superclocked w/ FTW BIOS  | 450W SFX PSU | 16GB GSKILL DDR4-2666 | Roccat Ryus MK Pro Keyboard & Roccat Kone XTD Mouse | Samsung 850Pro NVMe PCIe SSD 256GB
Working Laptop: Thinkpad T460p with Core i7 6700HQ @ 2.6 GHz | 32GB DDR4 RAM | Intel HD 530 | GeForce 940MX | 256 GB Crucial M500 SSD
https://linustechtips.com/topic/67020-hd-7990-crossfirex-gpu-usage-problem/
thats mostly because of your cpu but dont expect it to run at %100 with all games.
Is my CPU really THAT much of a Bottleneck? I cant imagine that by any means... But then why does it only crack up above 40% in Tomb Raider and no other game?
no i mean gpu usage dont expect it to run at %100 at every game because you might experience cpu bottleneck.
FX8120 is not that bad with new optimizations but still bit early to talk about it
Yes, your CPU is that bad... you are trying to run a crossfire 7970 which both need a fast single thread on a CPU with one of the worst single thread we had for a while... even Phenoms had faster single thread, even really ooooold intel had faster single thread...
Get new CPU if you want to rip the benefits of crossfired 7970.
][ CPU: Phenom II x6 1045t @3,7GHz ][ GPU: GTX 660 2GB ][ Motherboard: Gigabyte GA-MA770T-UD3P ][ RAM: 8GB @1450Mhz CL9 DDR3 ][ PSU: Chieftec 500AB A ][ Case: SilentiumPC Regnum L50 ][ CPU Cooler: CoolerMaster Hyper 212 Evo & Arctic MX4 ][
What games did you not get good GPU load? If they are non-demanding games like Source games then I wouldn't worry.
CoolerMaster CM 690 II Basic | Intel i7-2600 | CoolerMaster Hyper 212+ 2x Zotac GTX 1070 AMP! Edition
Asus P8Z77-V LK | 2 x 4GB Kingston HyperX DDR3 1600MHz CL9 | SeaSonic M12ii 850W 80+ Bronze Crucial M4 128GB
Okay so would a i5 4440 be enough? Then i could upgrade to Intel Haswell including a Mobo (ASRock Fatal1ty H87) for < 250€
I guess i would go with that then if that CPU does not bottleneck.. Btw: how many PCIe lanes does 1150 have again?
H87 > 1 PCI-E 16X
Z87 > 1 PCI-E 3.0 16X or 2 PCI-E 3.0 8X or 1 PCI-E 3.0 ×8 + 2 PCI-E 3.0 ×4
not sure but it might be 24
This could also be attributed to a lack of crossfire profiles in the games you play. Tomb raider was developed alongside AMD so it definitely has a crossfire profile. What are the other games you play as they may not be compatible with crossfire?
Corsair 350D - ASUS Maximus V Gene - Intel 3770K @ 4.6Ghz - Corsair H100i - G-skill Trident X 2666Mhz 4x4Gb - 2 x EVGA GTX 680 Classified 4Gb @ 1250Mhz - Corsair 860i - 2 x Samsung 840 Pro 240GB (Raid 0)
