In a nutshell I have a school project that wants me to convert an entered binary number to a decimal.
Program should go something like this:
User enters binary number -> binary number is converted one digit at a time -> decimal number is displayed.
I am very new to C and programming in general. If you have any tips or snippets of code you could share that would be great.
Thanks very much!
https://linustechtips.com/topic/670185-need-help-converting-binary-to-decimal-in-c/
10 minutes ago, Solace_ said:
yes I do
Great! This is actually a pretty simple thing to do.
Here's the algorithm:
  1. get the users input
  2. initialize an integer to 0
  3. Put the users input into a char array
  4. Reverse the char array
  5. Iterate through the char array from smallest index to largest doing steps 6 and 7
  6. If the current char in the array is character '1', then the integer is equal to itself plus 2 to the power of the current index of the array (integer += 2index)
  7. If the current char in the array is character '0', do nothing
  8. Output the integer.
Can you post your code when you're done?
ENCRYPTION IS NOT A CRIME
thanks very much, I will certainly try and remember to.
Thanks very much!
int getDecimal (int binary){
	if (binary == 0){
		return 0;
	int decimal = 0; // keep track of the total
	int j = floor(log10(abs(binary))) + 1; // returns how many digits are in the binary number
	int i = 0; // using i to iterate through each digit in the for loop.
	for int (; i < j; i++){ //starting with the left most digit start adding up the value for each position.
			decimal+= binary[i]^j/2; // Adds the decimal value of the binary position to the end result.
			j--; // takes j to the next digit so it can take the correct power.
	return decimal;
I didn't test this, but it should work I think.
CPU: Ryzen 5950X Ram: Corsair Vengeance 32GB DDR4 3600 CL14 | Graphics: GIGABYTE GAMING OC RTX 3090 |  Mobo: GIGABYTE B550 AORUS MASTER | Storage: SEAGATE FIRECUDA 520 2TB PSU: Be Quiet! Dark Power Pro 12 - 1500W | Monitor: Acer Predator XB271HU & LG C1
Implementation of @straight_stewie 's algorithm (sort of)
#include <stdio.h>
#include <string.h>
int main(void)
	//Maximum amount of bits user can enter. +1 because '\n' gets recorded.
	const int  MAXBITS = (sizeof(unsigned int) * 8) + 1;
	//Get binary number from user into InBuffer.
	char InBuffer[MAXBITS];
	printf("Enter binary number: \n");
	fgets(InBuffer, MAXBITS, stdin);
	int Length = strlen(InBuffer) - 1; //-1 because '\n' gets recorded.
	//Loop trough each character in the input string.
	unsigned int Result = 0;
	for (int i = 0; i < Length; i++)
		//Check for invalid characters.
		if (InBuffer[i] > '1' || InBuffer[i] < '0')
			printf("Invalid binary number entered!\n");
			return 1;
		//Multiply each char with it's bitvalue and add to result.
		Result += (InBuffer[i] - '0') * (1 << (Length - i - 1));
	printf("Result: %d\n", Result);
	return 0;
