Hi I just bought a new graphics card the 1070. I installed it and turned it on. It posted and I turned it off. When I tried to turn it back on its not posting any more. Ive checked all the cords they r all plugged in. I have removed the graphics card and plugged it back in and still not working. I also plugged my old graphics card back in and its still not posting. Anyone have any idea what I could do to solve this?
https://linustechtips.com/topic/669690-i-need-some-help-please/
Reseat the CMOS Battery
If your motherboard does not have a CLEAR CMOS jumper, you can often clear its CMOS settings by removing the CMOS battery and replacing it. The CMOS battery provides power used to save the BIOS settings – this is how your computer knows how much time has passed even when it’s been powered-off for a while – so removing the battery will remove the source of power and clear the settings.
http://www.howtogeek.com/131623/how-to-clear-your-computers-cmos-to-reset-bios-settings/
https://linustechtips.com/topic/669690-i-need-some-help-please/#findComment-8636938
5 minutes ago, WaffleTiger13 said:
Did you just put the motherboard in the case b4 this happen?
also what kind of power supply do you have?
no I only did a video card swap. All my components have been working since I got them which was like 6 months ago.
https://linustechtips.com/topic/669690-i-need-some-help-please/#findComment-8637582
