Where are volume controls now?
Mysterio415
Windows just updated again so im sure there are a whole host of new scavenger hunts, first of which being the volume. The icon is gone. Where is it now?
Uhhh...just updated mine, icon still in the same place. Do you still have sound?
CPU: AMD Sempron 2400+ / MOBO: Abit NF7-S2G / GPU: WinFast A180BT 64MB / RAM: Mushkin DDR333 256MBx2 / HDD: Seagate Barracuda 7200RPM 120GB
click on speaker icon, in bottom right, (or the list of small icons in the consolidated list).
The speaker icon isnt there any more, thats the point.
Go to Settings > Personalize > Taskbar > Turn System icons on or off > enable volume
I make Rainmeter things and other art :D
Restart explorer.exe. It works for me
CPU: Intel Core i7 8700
GPU: Gigabyte GeForce GTX 1070
MOBO: ASUS Z370-F STRIX
RAM: 16GB Corsair Vengeance DDR4 2133MHz
The update was more than likely rushed when MS realised that the last Cumulative update had a problem because it required IE, something that was removed in a previous Windows build.
Link:
But @I Need A PC Build ASAP is probably correct too OR maybe the higher-ups at MS wanted to counter the latest Apple product the iPhone 7 which is headphone jack-less and got flustered on the delivery part of the project...:S
Those who deny freedom to others deserve it not for themselves (Abraham Lincoln,1808-1865; 16th US president).
