So I was looking to get custom white cables from cable mod but I know shit about cables and its my first time build. What cables do i need?
http://pcpartpicker.com/list/KkNwYr
PCPartPicker part list: http://pcpartpicker.com/list/KkNwYr
Price breakdown by merchant: http://pcpartpicker.com/list/KkNwYr/by_merchant/
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($227.99 @ SuperBiiz)
CPU Cooler: Deepcool CAPTAIN 240EX WHITE 153.0 CFM Liquid CPU Cooler  ($94.99 @ SuperBiiz)
Motherboard: MSI Z170A MPOWER GAMING TITANIUM ATX LGA1151 Motherboard  ($228.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory  ($79.88 @ OutletPC)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($69.99 @ SuperBiiz)
Video Card: Asus GeForce GTX 1070 8GB Video Card  ($444.99 @ NCIX US)
Case: NZXT S340 (White) ATX Mid Tower Case  ($66.69 @ SuperBiiz)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($78.99 @ SuperBiiz)
Total: $1292.51
Generated by PCPartPicker 2016-09-30 23:05 EDT-0400
https://linustechtips.com/topic/669327-cable-mod-help/
I'd get the basic set. If you want some SATA data, you could get those as well from Cable Mod.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/669327-cable-mod-help/#findComment-8633513
3 minutes ago, Franpadi said:
So that will cover the MOBO, CPU, RAM, COOLER and GPU?
It'll cover PCIe (GPU), 4+4 pin (CPU), and 24-pin (motherboard) and SATA power (?) if I remember correctly.
https://store.cablemod.com/product/cablemod-e-series-g2-p2-basic-cable-kit-black-blue/
Edit: No SATA power.
https://linustechtips.com/topic/669327-cable-mod-help/#findComment-8633520
Just now, Franpadi said:
Does the cooler or ram need extra power?
No. Those plug directly into the motherboard for power. The AIO may require a Molex.
https://linustechtips.com/topic/669327-cable-mod-help/#findComment-8633526
Thanks a lot you were really helpful
You could get the full kit, but I'd recommend checking what cables you'll need and see if the custom configurator will produce a better match for less.
https://linustechtips.com/topic/669327-cable-mod-help/#findComment-8633534
Just my opinion, but I would change the PSU into a G2 if you have the money as they are more reliable and built sturdier. Remember, 80+ Gold is just an efficiency rating. It has nothing to do with the quality of the components.
i5-8600K -  Asus Strix Z370E - Asus GTX 1060 Strix - EVGA 650W P2 - Samsung 970 Pro 500GB - G.Skill TridentZ 16GB
https://linustechtips.com/topic/669327-cable-mod-help/#findComment-8633558
Yeah I did some digging and I will get the g2.
https://linustechtips.com/topic/669327-cable-mod-help/#findComment-8635660
