Not enough power
CPU: A8-5600K GPU: MSI RX 480 GAMING X 4GB MOBO: ASUS A55BM-PLUS
RAM: 2x 4GB Samsung DDR3-1600 1.25V PSU: Corsair CX430 CASE: Enermax Ostrog Windowed STORAGE: PNY CS1111 120GB / Hitachi 1TB 7200RPM OS: Windows 10 Pro & macOS Sierra 10.12.3
10 minutes ago, Mobi10 said:
Mobo is asus maximus vi hero
Cooler?
CPU - i7-4790k | CPU Cooler - NZXT Kraken X53 | Motherboard -  Asus Gyphon Z97 Armour Edition | RAM - Corsair Vengeance (2x8GB) 2400Mhz | Graphics Card - MSI GTX 1070 | Power Supply - Corsair CS750M | Storage - Seagate 1TB HDD | Samsung 500GB 850 Evo | Case - Fractal Design ARC Mini R2 | Colour Theme - Generic Red & Black
Operating System - Windows 10 Pro | Peripherals - Corsair RGB Mechanical K70 Keyboard/Corsair M65 Mouse
Click here to give a damn
1 minute ago, Mobi10 said:
Red, under 24 pin cable
Sorry. I mean whats the cooler you're using?
Can you get beyond BIOS?
What CPU and BIOS? and which OS?
ASUS Crosshair VIII Dark Hero X570**AMD Ryzen 5800X**16G Corsair Vengence RGB 3600Mhz **ASUS Strix RX6700XT OC**Corsair H150i RGB Platinum AIO**Samsung 2-2TB 970 EVO Plus m.2**2-860 2 1/2 EVO 1Tb SSD's**Creative Sound Blaster Z**Corsair HX1200i PSU w/Black sleeved corsair Cables**Corsair 5000D Airflow**BenQ XL2730Z 1440p 144Hz 27"**BenQ XL2720Z 27"**Corsair K95 RGB Platinum Keyboard**Roccat Kave 5.1 Gaming headset,Roccat Kone Pure Black Gaming mouse**Windows 10 PRO
_____________________________________________________________________________________________________
Just now, Mobi10 said:
It is Corsair H100i/v2
I can't even see the bios, I mean no display, just running fans
I did a quick google.
Is this LED you're talking about got numbers on it such as your temperatures?
If so, and it is 00, it means that the CPU isn't initializing. (Was a quick google)
I also found another answer saying you should just go around checking all the wires are firmly in, re-seating the ram and CPU and rebooting.
That is right.. I get 00 and cpu_led red light. I've already tried reseating wires RAM and CPU but no luck with i5 4690k but the odd thing is that it works when i replace it with the old one "i3 4130"
Thanks for the reply!
Whats the CPU?
Put your i3 back in and update the bios.
you need bios 1504 to read that CPU.forgot to quote you so you get the notification
1 hour ago, Mobi10 said:
I finally updated the bios ti 1504 and it's still the same! Is there any other metod to fix this problem?
Did you buy the CPU new or used?
Well,recheck everything,all power connections etc.Otherwise from what I was reading while googling,it's gonna be tough,but most show Motherboard failures and a few CPU ones.
Since yours works with the i3,gonna say its probably the CPU.
Good luck.
Good luck.
thanks for the help :D:D , solved the problem, I need to update my BIOS to v1505 then worked my new CPU (Intel i5 4690k) :D:D:D
