Shadowplay mic problems
Go to solution Solved by ShadowCaptain,
you could try disabling webcam audio, but in shadowplay settings you should be able to manually select the mic you want to use
so lets start with this, the new shadowplay update is shit.
After the update shadowplay wont wanna record on the right mic, and i cant go to the last update.
i have a blue snowball and its choosing the webcam mic.....
the blue snow ball is the deffault device ( or what ever you call it )
also i have been to the settings.
so how do i make it use the right mic.
https://linustechtips.com/topic/669059-shadowplay-mic-problems/
https://linustechtips.com/topic/669059-shadowplay-mic-problems/#findComment-8630532
i allready unplugged the webcam and after that there is no audio.
i coud change the mic from shadowplay. it was hidden in the mute button.
thanks!
https://linustechtips.com/topic/669059-shadowplay-mic-problems/#findComment-8630545
thanks!
no worries :D
https://linustechtips.com/topic/669059-shadowplay-mic-problems/#findComment-8630564
